Pabbly Connect Team•Updated Aug 19, 2026•3 min read
On this page
This guide walks you through generating an access token to enable Instagram DM automation using the Meta Developer Platform and creating a connection with it in Pabbly Connect.
Overview:
Go to Meta Developers Portal
Create a New App
Select Use Cases
Select Business Portfolio
Open API Setup with Instagram Login
Add Required Messaging Permissions
Add Your Instagram Account as Tester
Accept the Tester Invitation
Access Token and Webhooks
Generate Access Token and Copy Account ID
Configure Webhooks
Publish Your App
Create a connection in Pabbly Connect
Prerequisites
A public Instagram Professional or Business account
