Building Forms & Fields
Updated Nov 12, 2026
In this section
- Do you have Limitations on characters?
- How to add a field in my form, to upload multiple files?
- How to change Field Width?
- How to change form width?
- How to create multi page forms?
- Is it possible to update a new field to an existing Form once embedded on a website, or do I need to pay and create a new one?
- Question using a scale rating
- What do social icons settings do?
- What is Hidden Field?
- What is a pre-fill key?
- What is form scheduling, how does it work?
- What is the use of Logic Field?
- What is the use of the Conditional Redirect feature? Is it the same as Logic Field?
