Table of Contents
- Overview
- Prerequisites
- Security Requirement: Whitelisting Pabbly Integration Server
- Step 1: Whitelist IP Address in MongoDB Atlas
- Step 2: Retrieve MongoDB Connection String
- Step 3: Establish MongoDB Connection in Pabbly Connect
- Step 4: Configure MongoDB Action
- Step 5: Test and Save the Workflow
- Common Errors and Troubleshooting
- Final Verification Checklist
1. Overview
The MongoDB integration in Pabbly Connect enables users to automate database operations such as inserting, updating, retrieving, and deleting records from
MongoDB Atlas through workflow-based automation.
To ensure secure and uninterrupted communication between Pabbly Connect and MongoDB Atlas, proper IP whitelisting and authentication are mandatory.
2. Prerequisites
Before proceeding, ensure the following requirements are met:
- An active MongoDB Atlas account
- A running MongoDB cluster
- A MongoDB database user with appropriate permissions
- Access to Pabbly Connect
3. Security Requirement: Whitelist Pabbly Integration Server
MongoDB Atlas enforces IP-based access control. To allow Pabbly Connect to communicate with your cluster, the Pabbly Integration Server IP must be whitelisted.
Server IP: 157.180.81.74
Important: Failure to whitelist this IP will result in connection and authentication failures.
4. Step 1: Whitelist IP Address in MongoDB Atlas
4.1 Sign in to MongoDB Atlas
📷 Screenshot: MongoDB Atlas Dashboard
4.2 Select Your Project
- Choose the project that contains your MongoDB cluster
📷 Screenshot: Project Selection
4.3 Open Network Access Settings
- Navigate to Network Access from the left sidebar
- Open the IP Access List section
📷 Screenshot: IP Access List
4.4 Add Pabbly Integration Server IP
- Click Add IP Address
- Enter the IP address: 157.180.81.74
- (Optional) Add a description
- Click Confirm
📷 Screenshot: Add IP Address
Expected Outcome:
The IP address appears with an
Active status.
5. Step 2: Retrieve MongoDB Connection String
5.1 Navigate to Clusters
- Go to Database → Clusters
- Click Connect on the target cluster
📷 Screenshot: Cluster Overview
5.2 Select Connection Method
- Choose Connect your application
📷 Screenshot: Connection Options
5.3 Copy Connection String
- Select the appropriate driver
- Copy the provided connection string
Example: mongodb+srv://<username>:<password>@cluster0.mongodb.net/<database>
📷 Screenshot: Connection String
ℹ️
Note:
Replace
<username>,
<password>, and
<database> with your actual MongoDB credentials.
6. Step 3: Establish MongoDB Connection in Pabbly Connect
6.1 Access Pabbly Connect
- Log in to Pabbly Connect
- Create a new workflow or open an existing one
6.2 Add MongoDB Action
- Click Add Action
- Select MongoDB
- Choose the required action/event
6.3 Create a New Connection
- Click Add New Connection
- Paste the MongoDB connection string
- Click Connect
Expected Outcome:
The connection status displays
Connected.
- Select the database name
- Select the collection name
- Map all required input fields according to the selected MongoDB action
ℹ️
Note: Ensure all mandatory fields are mapped correctly to avoid execution failures.
8. Step 5: Test and Save the Workflow
8.1 Test the Action
- Click Save & Send Test Request
- Review the response returned by MongoDB
8.2 Save and Enable Workflow
- Click Save
- Enable the workflow for execution
Expected Outcome: The workflow executes successfully without validation or runtime errors.
9. Common Errors and Troubleshooting
Connection Failed
- Verify IP address is whitelisted
- Check MongoDB username and password
- Confirm database name in the connection string
Authentication Failed
- Ensure MongoDB user permissions are correctly assigned
- Verify read/write access for the database
Timeout or Network Error
- Allow a few seconds after IP whitelisting
- Retry the connection
10. Final Verification Checklist
✔ MongoDB Atlas account active
✔ Pabbly Integration Server IP whitelisted
✔ MongoDB user created with correct permissions
✔ Connection string verified
✔ MongoDB connected in Pabbly Connect
✔ Action tested successfully
✔ Workflow saved and enabled
Completion Status
You have successfully configured MongoDB with Pabbly Connect. Your workflows are now ready to perform secure and automated database operations.
