Table of Contents
- Overview
- Important Security Requirement
- Before You Start (Prerequisites)
- Allow IP for Cloud-Hosted PostgreSQL
- Allow IP for Self-Hosted PostgreSQL
- Connect PostgreSQL in Pabbly Connect
- PostgreSQL Connection Fields Explained
- Available PostgreSQL Actions in Pabbly Connect
- Test the Connection
- Common Problems & Easy Fixes
- Final Checklist
- Completion Status
1. Overview
Pabbly Connect allows you to connect your PostgreSQL database and automate tasks like inserting, updating, fetching, and deleting database records — without writing code.
To make this work, your PostgreSQL server must allow access from
Pabbly Connect’s integration server.
2. Important Security Requirement
PostgreSQL blocks unknown servers by default.
To connect PostgreSQL with Pabbly Connect,
you must allow the following IP address:
Pabbly Integration Server IP: 157.180.81.74
⚠️ If this IP is not allowed, PostgreSQL connection will fail.
3. Before You Start (Prerequisites)
Make sure you have:
- A running PostgreSQL database
- Database details:
- Host
- Port (usually 5432)
- Database name
- Username & password
- Access to your server or cloud provider
- Access to Pabbly Connect
4. Allow IP for Cloud-Hosted PostgreSQL
(AWS RDS, Supabase, Neon, Render, Azure, GCP, etc.)
- Log in to your cloud provider.
- Open your PostgreSQL database settings.
- Go to Security / Firewall / Network Access.
- Allow this IP address: 157.180.81.74
- Ensure PostgreSQL port (5432) is allowed.
- Save the changes.
✅ Cloud PostgreSQL is now accessible from Pabbly Connect.
5. Allow IP for Self-Hosted PostgreSQL
(Server / VM / On-Premise)5.1 Allow IP in Server Firewall
Allow incoming traffic from:
157.180.81.74
(This is usually done by your system administrator.)
5.2 Allow IP in PostgreSQL Settings
- Open the pg_hba.conf file.
- Add this line:
host all all 157.180.81.74/32 md5
- Save the file.
- Restart or reload PostgreSQL.
✅ PostgreSQL is now ready to connect.
6. Connect PostgreSQL in Pabbly Connect
- Log in to Pabbly Connect.
- Create a new workflow or open an existing one.
- Click Add Action → Select PostgreSQL (Server).
- Click Add New Connection.
- Fill in the connection details (explained below).
- Click Save.
✅ Connection status should show
Connected.
7. PostgreSQL Connection Fields Explained
While creating the connection, you will see the following fields:
New Connection Name
Give a name to identify this connection.
Example: Production PostgreSQL
Username
Enter your PostgreSQL database username.
Example: postgres, admin, db_user
Password
Enter the password for the above username.
Database Host
Enter your PostgreSQL server hostname.
Examples:
- db.example.com
- xyz.supabase.co
- your-db.rds.amazonaws.com
⚠️ localhost or 127.0.0.1 will NOT work.
Database Name
Enter the name of the database you want to connect to.
Example: prod_db, app_data
Database Port
Enter the PostgreSQL port number.
Default: 5432
(Use a different port only if your server uses one.)
SSL Required
Choose whether SSL is required.
- Yes → Recommended for most cloud databases
- No → Only for local or internal servers
ℹ️ Most cloud PostgreSQL providers
require SSL.
8. Available PostgreSQL Actions in Pabbly Connect
Once connected, you can use the following PostgreSQL actions:
Insert Row
Adds a new row (record) into a table.
Update Row
Updates existing data in a table based on conditions.
Get Rows
Fetches data from a table based on filters or conditions.
Delete Rows
Deletes one or more rows from a table.
⚠️ Use carefully, as deleted data cannot be recovered.
Run SQL Query
Run a custom SQL query directly on your database.
Examples:
- SELECT queries
- JOIN queries
- Advanced custom logic
⚠️ Recommended for advanced users.
9. Test the Connection
- Select any PostgreSQL action.
- Click Save & Send Test Request.
- Check the response.
If data is returned or affected successfully, the setup is complete.
10. Common Problems & Easy Fixes
Connection Failed
- Check IP 157.180.81.74 is allowed
- Verify host and port
- Ensure PostgreSQL is running
Authentication Error
- Recheck username and password
- Ensure user has database access
Timeout Error
- Wait a few minutes after allowing IP
- Restart PostgreSQL
11. Final Checklist
✔ PostgreSQL is running
✔ Pabbly IP allowed
✔ Firewall configured
✔ Database credentials verified
✔ Connection tested successfully
✔ Workflow enabled
12. Completion Status
PostgreSQL is successfully connected with Pabbly Connect.
You can now automate your database operations smoothly and securely.
