What is the Transformation Right-Side Modal View in Pabbly Hook?
Pabbly Hook Team•Updated Nov 12, 2026•3 min read
On this page
Transformation Modal View in Pabbly Hook
Definition
The Transformation Modal View in Pabbly Hook allows users to view and manage the details of a specific transformation created within the system. This feature is accessible by selecting a transformation from the "Transformations" list on the left-hand side vertical navigation bar.
Features and Fields Explained
1. Transformation Name
Purpose: Identifies the name of the selected transformation for quick reference.
Editable: No, it reflects the name assigned during transformation creation.
2. Created At
Purpose: Indicates the exact timestamp when the transformation was initially created.
Format: Follows the MMM DD, YYYY HH:MM:SS format for easy readability.
3. Transformation ID
Purpose: Provides a unique identifier for the transformation. This is particularly useful for debugging or referencing the transformation in API calls.
Editable: No, it is automatically generated by the system.
4. Last Updated At
Purpose: Displays the most recent timestamp when the transformation was modified. Useful for tracking changes.
Format: Same as the "Created At" field.
5. Transformation Code
Purpose: Shows the actual JavaScript code used for the transformation.
Key Features:
Syntax Highlighting: Ensures better readability of the code.
Code Examples: Includes comments for common use cases, such as:
Changing date formats.
Renaming fields.
Adding conditional fields based on specific logic.
Example Use Cases in Transformation Code
Change Date Format:
if (request.payload.order_date) {
const [month, day, year] = request.payload.order_date.split('/');
request.payload.order_date = ${year}-${month}-${day};
The inclusion of the timezone ensures clarity about the specific time zone the timestamp refers to. This is particularly useful in scenarios involving global teams or when debugging logs and events that occur across multiple time zones.
Components:
Date and Time: November 29, 2024 16:09:39.
UTC Offset: (UTC +05:30).
Time Zone Region: Asia/Kolkata.
Display:
This detail is prominently displayed below the "Transformation Name," ensuring it is visible and easy to understand.
Usage Implications
Debugging:
When comparing timestamps in logs or events from other systems, ensure alignment with the specified timezone.
Global Team Collaboration:
Facilitates smooth communication by providing clarity about the timezone when a transformation was created.
Compliance and Auditing:
Useful for timestamp validation in regions where precise logging and timezone tracking are required for compliance.
This additional detail ensures that users can track transformations with precision, even in a multi-time-zone environment.
Best Practices
Validate Code: Before saving, ensure your JavaScript code is error-free to avoid runtime issues.
Test Changes: Test the transformation using sample payloads to confirm it behaves as expected.
This documentation provides a comprehensive understanding of the transformation modal view in Pabbly Hook, ensuring users can efficiently manage and customize their transformations.
