App Integration Guide (Developers)
| Name | Example Call | Expected Result |
| Get current date-time in encrypted UTC format | {{gc_curr_date_time}} | 2021-09-21T07:14:57+00:00 |
| Get date-time a day ago from the Current Date-time in encrypted UTC format | {{pc_yesterday_curr_date_time}} | 2021-09-20T07:20:37+00:00 |
| Get current date-time in encrypted UTC format (with addition of 3min) | {{gc_curr_date_time_plus_3m}} | 2021-09-21T07:20:37+00:00 |
| Unix TimeStamp UTC | {{pc_utc_timestamp_now}} | 1627999296 |
| Unix TimeStamp in User's Local Time Zone | {{pc_local_timestamp_now}} | 1627979363 |
| Human-readable date and time in UTC | {{pc_utc_human_now}} | MM/DD/YY hh:mmAM/PM (Ex:, 01/15/21 06:05PM). |
| Human-readable date and time in Local Time Zone | {{pc_local_human_now}} | MM/DD/YY hh:mmAM/PM (Ex:, 01/15/21 06:05PM). |
| Server Date in UTC format | {{pc_utc_date_now}} | YYYY-MM-DD (Ex: 2021-08-23) |
| Server Date in local format | {{pc_local_date_now}} | YYYY-MM-DD (Ex: 2021-08-23) |
| Used for boolean value as "true" | {{##boolean:true##}} | TRUE (Refer to point 3 for the screenshot) |
| Used for boolean value as "false" | {{##boolean:false##}} | FALSE (Refer to point 3 for the screenshot) |
| Used for assigning null value | {{skip}} | null will be passed as a value in JSON (Refer to point 1 for the screenshot) |
| Removes a key value from the Raw JSON if field is blank | {{pc_skip_field}} | Dynamic JSON (Refer to point 4 for the screenshot) |
| Removes object from the Raw JSON if child fields are blank | {{pc_skip_field_with_parent}} | Dynamic JSON (Refer to point 5 for the screenshot) |
| Used for assigning blank value | {{blank}} | Blank space will be added as the value in JSON (Refer to point 2 for the screenshot) |
| Used for assigning the blank space | {{space}} | Space will be added as value |
| Used for assigning random hex encrypt value | {{hex_enc_bytes}} | 4658514243455a58 |
| Skip array fields | provide this in default value of array key : {"id":"{{pc_skip_field_with_parent}}"} | Dynamic JSON - (Refer to point 6 for the screenshot) |
| Modified DateTime (In GMT) | Provide date time in a specified format and modify the date using time value in minutes. Here is the syntax: [{{modifyDateTime_DateFormat_ModifiedTime}}] E.g. 1. [{{modifyDateTime_Uv_-15}}] or [{{modifyDateTime_Uv_15}}] Here we have subtracted and added 15 minutes respectively to the current time. 2. [{{modifyDateTime_Y-m-d}}]T[{{modifyDateTime_H:i:s_-10}}]Z 3. [{{modifyDateTime_Y-m-d_40320}}]T[{{modifyDateTime_H:i:s}}]Z Here we have added 40320 minutes to the current date. Please note this function will work both using the API by the Pabbly module and also in the Pabbly Connect developers platform and in JSON everywhere. It will also work in the query parameters. Click here for the date formats. | 1. 1680084369000 2. 2023-03-29T10:57:27Z 3. If the current date is 2023-09-25T07:28:01Z. Then the value will be printed as 2023-10-23T07:28:01Z after the addition of 40320 minutes. |
| Get Workflow Step ID | {{workflow_step_id}} Note: It'll not work in case of trigger step. | IjU3NjYwNTY5MDYzNzA0MzEi_pc |
