How to Integrate your application with Pabbly Connect: Integration Guide · Pabbly Connect · Pabbly Docs
App Integration Guide (Developers)
Pabbly Connect Team•Updated Aug 24, 2026•1 min read
Users in Pabbly Connect can generate different Webhook URLs for each of their workflows.
Inside your platform, you need to create a UI listing all the available trigger events and a field for each trigger where the user can paste his webhook URL.
Your customers can then add the Webhook URL and select the event inside your application when that webhook will be sent to Pabbly Connect.
You need to send the webhook to the added Webhook URL when that chosen event happens inside your application.
Sometimes, you just have one key event in your application that you want to send a webhook for, in that case, just create a webhook for that one event. No need to give multiple selection options for different events.
