Getting Started
Quick answers to the questions people ask most about Pabbly Studio.
No. You describe what you want in plain words, and Pabbly Studio writes the code for you. If you are curious, you can look at the code in the Files tab, but you never have to.
A first build usually takes a few minutes. Small changes usually take less than a minute.
You can build anything that runs in a web browser. This includes business tools, dashboards, CRMs, booking systems, client portals, landing pages, websites, forms, calculators and simple games.
Yes. Every app is published on its own .pabbly.app link as soon as it is built. Every change you make also goes live automatically.
Yes. Apps are designed to work on desktop, tablet and phone, and Pabbly Studio checks each build on phone and desktop. You can use the screen size button in the builder to preview your app at each size.
Yes. Every app has its own database. You can browse the data it has saved in the Data tab.
Yes, on the Standard and Unlimited plans. In the builder, click Share app › Use your own domain.
AI credits pay for the work Pabbly Studio does on your messages. Every message uses some credits. Big changes use more credits, while small changes and questions in Plan mode use fewer.
To see how many credits a reply used, hover over its timestamp. For more details, see How AI Credits Work and How to Buy More.
Pabbly Studio cannot start any new changes until you buy more credits. Your apps keep working and stay live.
It depends on your plan. The Free plan includes 1 active app and the Standard plan includes 3. The Unlimited plan has no fixed limit, subject to fair usage. Deactivated apps do not count towards your limit.
Yes. Open the Versions tab and click Rollback on the version you want to go back to. Your app's data is not affected.
No. A rollback only restores how the app looks and works. Your saved records stay as they are.
Yes. On the dashboard, click the ⋮ button on your app's row and choose Download code.
No. Visitors to your app only see the app itself. Your chat, versions, files and settings can only be seen in your Pabbly Studio account, and by team members you share the app with.
Yes, on the Standard and Unlimited plans. Add them as a team member and choose Viewer (can only look) or Editor (can make changes). See How to Add Team Members to Your Apps.
Yes. Ask for the feature in the chat. If it needs a key from another service, Pabbly Studio tells you the name to use. You then add the key in the Environment tab.
Yes. See How to Connect Pabbly Studio to Claude or ChatGPT.
Click the ? icon at the top right of Pabbly Studio and choose Create a Ticket.
If you still have any questions, feel free to reach out to us.
